carb butterfly with no screw in center
johncbass created the topic: carb butterfly with no screw in center
i have seen a carb mod where there is no screw in the center ...who makes this modification...HELP...tired of the screw coming loose ant destroying my engines
#25293
Hot Rods replied the topic: carb butterfly with no screw in center
The carb you are referring to, was a 257 done by Insane boats.
The screw coming lose can be fixed by complete cleaning of the male and female threads with acetone, and applying red Loctite on assembly. Extra insurance is to peen the end of the threads after assembly. Also make sure your end points on the servo are just set to stop and WOT. If they are forcing the butterfly, it can start to losen the screw.
#25295
Tahoe1970 replied the topic: carb butterfly with no screw in center
Yes Dennis has it right , Problem solved when done correctly !
#25312
CC Racing Engines replied the topic: carb butterfly with no screw in center
I could not agree more.
Carlo
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#25332
