RCMK k30s porting!!!!
kiwi racer created the topic: RCMK k30s porting!!!!
Has anybody out there done this yet as the head is quite different to the old s254 ,
#20225
Scott replied the topic: Re: RCMK k30s porting!!!!
K30's are indeed different !!
Not sure of the latest production cylinders ? .. but ALL the K30 I have seen are MIS-ALIGNED in terms of the closed transfer passage to outlet window within cylider.
This creates a HUGE flow restriction and can be made larger with some careful hogging out or ** REMOVE the cylinder wall portion of the transfer passage making it an OPEN TRANSFER design like the S254/Evo jugs.
#20227
kiwi racer replied the topic: Re: RCMK k30s porting!!!!
Thinks for that Scott
We have just finished doing that and have taken photos , will post soon
Havn't put together yet as racing my redline sport hydro this weekend
Wil post outcome when it's together and running
P.S just for interest my sport hydro is an " herzog " number 005 !
#20235
mickbuy0 replied the topic: Re: RCMK k30s porting!!!!
Hi I would be very interested in hearing results and seeing pictures of your porting on the K30S
Regards
#20257
lexo replied the topic: Re: RCMK k30s porting!!!!
Could you upload those pics? Very interesting!
#20284
NOT MY PICTURES ... But ones I took off JRCBD showing a modified K30 with enclosed transfer port uncovered ;)
#20286
Hi,thanks for the pictures,(K30s barrel) what changes would you make to the piston and base gasket thickness with these mods on the pictured barrel?
#20295
Piston maybe just some profiling alongs sides of and on pin boss areas.
Gaskets need to be opened up in size for the bigger transfer passages.
If splitting cases ? Trough above bearings need to be further cut back again matching gasket to the cylinders transfer passage shape.
It's called BLUEPRINTING :laugh:
#20298
david36pt replied the topic: RCMK k30s porting!!!!
Hi Scott
Hope you are fine
I m going to try to port my K30rz .Do you have more fotos of the head afther porting??And the piston?
Can you advise what is the opening in the transfer that we see in the photo like an inlet??
Regards
#22340
marc replied the topic: RCMK k30s porting!!!!
Looks like a brass fitting... Possibly a pulse tap? Can we see the outside of the jug a that area please?
#22341
Time to create page: 0.337 seconds
