26cc Marine Conversion
isuzudude created the topic: 26cc Marine Conversion
My question is... will a marine head work on an aircooled engine? I measured the bolt pattern with my calipers, and the dimension are exact. But is the porting the same? Even if it isn;t, will the engine at least run? I guess I should have said questionsssssssss. :dry: I seen several post of just machining the fins off, just looking for an easier way out :)
Thanks...Doug.
#17020
Ozpulse replied the topic: Re: 26cc Marine Conversion
If the heads are a straight bolt on swap(same make), there is no problem.
Of course you will also have to address the piston due to expansion differences. ;)
#17021
isuzudude replied the topic: Re: 26cc Marine Conversion
I didn't think about that part... :angry: :angry: :dry:
#17022
