spark plug help
goesman created the topic: spark plug help
My little echo gt200r has a NGK BPM8Y. Its a non resistor plug and it made my radio stuff go nuts. I am trying to find a resistor plug that will work. I have saw mention of a BMR7A. Could that work even though the heat range is a bit off. I would run to the parts store and ask them but if you knew the idiots that work in the stores around here, they probably try to sell me glow plugs to a diesel. I imagine the motor Yoda Scott can help me out on this one.
Thanks,
Dan
#16966
Scott replied the topic: Re: spark plug help
That plug is what you want and heat range should not be an issue IMO.
#16967
goesman replied the topic: Re: spark plug help
You the man scott. Thanks, now maybe i can get a first time test run in today.
#16968
Damn, run all over town and no spark plug. guess my first run of the prowler will be postponed until i can get one. :blush: :angry: :(
#16975
BMR6A is doable too and common heat range the older Zen 230's used.
Nippon Denso also makes an equivalent plug.
Or in a pinch the Champion RCJ-8 will work too.
#16976
idocdave replied the topic: Re: spark plug help
Ck a Honda bike shop if you have one near you they should have that plug.
Dave
#16987
