Full circle crank mod .... and other tricks ... wh
Scott replied the topic: Re: Full circle crank mod
Mholst wrote:My vented piston engines Propped and Piped to take advantage of the top end potential run in the low too mid 18K range.
#6226
Tahoe1970 replied the topic: Re:Full circle crank mod .... and other tricks ... wh
Milling out the case a bit to except the full circle is about it:laugh: Then making sure you select the right crank so you dont have to use an adapter.:dance2:
#6230
