can anyone point me away to find or buy a big bore kit for a 23cc zen engine?
Misshydro created the topic: can anyone point me away to find or buy a big bore kit for a 23cc zen engine?
we got a 23cc zen engine built/mod by M&D Designs. Engine looks barely used. would like to get more power out of it if possible? Unless this engine has power as is?
#15868
Woodie replied the topic: Re: can anyone point me away to find or buy a big bore kit for a 23cc zen engine
Miss Hydro.
I truly understand your needs regarding the Zen.
Sorry to tell you, I can't help you out, as my engine is a heavy 40 cc Blata with a very huge exhaust and a superior piston running at 17.400 rpm delivering 13,4 brute hp.
In respect of this I think someone less motorized should help you out here. :laugh:
Nice picture by the way. :kiss:
Scott replied the topic: Re: can anyone point me away to find or buy a big bore kit for a 23cc zen engine
Misshydro wrote:
If engine is an earlier 2 port g230, and indeed it is a M&D modified ? ... Then pretty safe in saying you have pretty much the best it's going to have in HP :cheer:
If it is a 4 port g231, then you could go with a modified g260 top end and find some more snort :huh:
#15871
Misshydro replied the topic: Re: can anyone point me away to find or buy a big bore kit for a 23cc zen engine
how would I know if its a 2 or 4 port engine without taking it apart? or do I have to take the jug off to find out?
#15898
Miss Hydro.
As said I'm not much into the zens, as my Blata just works as is.
But if you remove the jug for a closer wiew, we might get closer to solving the problem.
David McIntyre replied the topic: Re: can anyone point me away to find or buy a big bore kit for a 23cc zen engine
Maybe check out the forums on here. I'm pretty sure you can tell by looking. Different bolt pattern or something. Can't remember.
#15904
marc replied the topic: Re: can anyone point me away to find or buy a big bore kit for a 23cc zen engine
Misshydro wrote:
Look through the plug hole or ex port with a light with piston at bdc...you can see pretty good on the sides if there are 2 transfers or just 1.
If it's a real M&D modded 23 and still in good condition, probably a real good little motor as-is though. If you want to put a kit on it and its a old 2-port, you have to change crank case also. You basically just keep crank, flywheel, coils from old engine.
#15908
