Zenoah three bearing?
Mercury94 created the topic: Zenoah three bearing?
Can a RCMK crank case bearing be used in place of the seal on the output end of a Zenoah? If so what benefits would be gained or lost?
#14421
Scott replied the topic: Re: Zenoah three bearing?
Have done so for YEARS ... Zenoah has made a double sealed bearing that is factory used in the PU aircraft engine. Yes the DOUBLE sealed rcmk bearing will work fine.
Advantage is a more rigid and better supported crank, less vibration generally ... a win win IMO
#14423
Mercury94 replied the topic: Re: Zenoah three bearing?
Would it be possible to use the RCMK brass seal plate?
#14440
Mercury94 wrote:
No reason not too .. will fit just fine.
You will however need to shorten collet so it does not contact inner race of outboard bearing once going to 2 bearings on PTO side ;)
#14441
ian69 replied the topic: Re: Zenoah three bearing?
scott will this work on a two bearing hirev quickdraw .
#14493
ian69 wrote:Pretty sure it will being most of the more current QD's have 4 bearing bottom ends.
If on the older cases with only 2 main bearings, if the PTO end used the big bearing diameter seal it could be replaced by a third sealed bearing most likely.
#14495
thanks scott just checked it's got the small seal .maybe i can get it machined to take the bearing.
#14497
So your saying the crankcase is made so it uses a small seal like used on the MAG side on the PTO side as well ?
If thats the case, then live with it. Not practical or really doable taking the bearings O.D. bore outward to stack a second one along side it.
Just run it as is, your just fine as it is designed.
#14498
sorry it has the the thick seal so it's do able
#14499
