zenoah&quickdraw
ian69 created the topic: zenoah&quickdraw
will a zenoah top end fit on a quickdraw bottom end just wanting to no that's all thank's ian
#14045
Scott replied the topic: Re: zenoah&quickdraw
ian69 wrote:
No it does not fit, The Crankcases for Quickdraws own top end has a different bolt pattern and pretty sure decked at different height, so a No Go.
Quickdraw has or at times built a Billet 4 bearing crankcase just for the Zenoah/RCMK cylinders that is a direct bolt on.
#14048
Moofy07 replied the topic: Re: zenoah&quickdraw
Hi
If you are looking to go for a 4 bearing bottom end RCMK have several on offer, they are in various stages, ie. like just the crankcase and then more items on top.
Unless you have a Zen cyl and quickdraw bottom. then it is as Scott said it is a no go.
Hope this helps.
Moofy
#14051
ian69 replied the topic: Re: zenoah&quickdraw
thanks i was just wanting to no if the bolt patton was the same
#14059
thanks four the replys everyone
#14185
