Zen ignition vrs RCMK ignition.
Scott created the topic: Re: Zen ignition vrs RCMK ignition.
As with most things RCMK .... there later parts are better than the former ;)
Primary coil they work the same and WOULD STAY with the RCMK coil when used on RCMK cast cases, a Zen coil needs plastic trimmed & brass rivet head taken of too work.
As for SECONDARY coils, Zens GREY coil is near failure proof and a GREAT part.
RCMK's secondary with the writing on it tends to need tighter S/P gaps @ .015" to keep from misfiring at high rpm. The newest "Non Written on" coils seem now to be just fine and will fire .022-.024 gaps no problem.
#13676
Scott replied the topic: Re: Zen ignition vrs RCMK ignition.
Talking SECONDARY coil that has the plug wire and not the generator/trigger coil
#13690
The two systems are for practical reason the same, have really found no benefit in mix & matching ... sadly
#13701
Canadian Hot Rod RC Boats replied the topic: Re: Zen ignition vrs RCMK ignition.
Scott
My son and I are building a engine (from scratch) for his boat using:
- RCMK sx 254 case
- RCMK 1mm stroker crank
- J&G V2 top end kit
I have ordered a new Zen grey coil and red 'pickup' I was hoping to use.
DO I use the Zen flywheel or the RCMK flywheel - does it matter?
Do u need to use Zen ignition with Zen flywheel and same with RCMK?
Thanks
#13819
Canadian Hot Rod RC Boats wrote:Flywheel do work with either, tho I WOULD base my decision of which flywheel to use based upon WHO's crankshaft is in those cases .... so the tapers best match :P
#13820
