Zenoah Ignition Problems-----
Ed Sidders created the topic: Zenoah Ignition Problems-----
After several direct e-mails requesting this info , I'm posting it here.
This is what I do to all my Zenoah engines-saves a lot of trouble down the road with corroded connections. The braided wire is from the outer shield of a CB radio type coaxial cable. Clean all connection points as well as the plug and socket where the coils connect and use some type of electrical anti corrosion compound. I use Penetrox but I don't think that is available in small quanities.l Sorry about pic quality . I also ground the stuffing tube to the motor mount . This has solved some hard starting and high speed miss problems as well as some radio inteference issues. Hope this helps someone. Ed http://www.modelgasboats.com/media/kunena/attachments/legacy/images/2316_Zenoah_Ground_System002_jpgcbbb4fd98907f9f0b1da0490942a0afd
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/2318_Zenoah_Ground_System003_jpgc851856bf32155eaccfcf8b4b368589d
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/2320_Zenoah_Ground_System004_jpg5fda6930ab833678cfd68186ff7482d6
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/2322_Zenoah_Ground_System005_jpg20f40b437a51fd469df2a8f8d4af79b2
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/2324_Zenoah_Ground_System001_jpgc129826aa9a715e5d8980f627a28a6cb
#1304
Time to create page: 0.051 seconds
