Reed case engine wins first heat race in off shore in a cat.
Mazwan80 created the topic: Re: Reed case engine wins first heat race in off shore in a cat.
Doug,
That a great news for reed case engine. I will try my luck on next race in malaysia to been early next month and i will keep update. Doug have u try 472 octura and 257 prater prop..last sunday i used it and no lost speed on corners, my pipe length is around 12 inch
#13010
Ozpulse replied the topic: Re:Reed case engine wins first heat race in off shore in a cat.
How much do these go for?
I grew up with 2 stroke reed motors in all our bikes!
#13128
Wozza_au replied the topic: Re:Reed case engine wins first heat race in off shore in a cat.
<strong>Ozpulse wrote:</strong>Me to wish I still worked at the M/cycle repair shop, I could so use all the machining tools :)
You can get bolt on reed kits
powerslideracing.com.au/index....products_id=342
Not sure how much benefit you get as I would think some serious port work would be needed.They sound awesome when on full song do a search at youtube for
"Marine Trevor Simpson reed motor"
Wozza
#13134
Moofy07 replied the topic: Re:Reed case engine wins first heat race in off shore in a cat.
Hi,
I also grew up in those reedy days. Also if you did not know Carmen Bloise from Need for speed has those two section cones on his tuned pipes pipes. As he says 70's technology with a modern twist. It really is history repeating itself.
My 2 cents worth.
Moofy
#13247
Scott replied the topic: Re: Reed case engine wins first heat race in off shore in a cat.
earthsurfer wrote:
Am finding between early and late production RCMK cranks the ROD on pin bearing end has been narrowed allowing the Zenoah washers to install without mods.
Early rods have a small end width of @ .315" and need stock washers or thinned Zens.
Newer rods are now at .300" allowing Zen washers to be used.
FYI,
Scott
#13615
marc replied the topic: Re: Reed case engine wins first heat race in off shore in a cat.
Any of your guys going to the Gas Nats in Louisiana in November? I would like to see one of these perform first hand. Thanks.
#13616
