New CC Racing 2-stage tuned pipe.
marc created the topic: New CC Racing 2-stage tuned pipe.
I received my new 2-stage pipes from CC Racing today. Had a chance to do a little bit of testing in my cat...THIS PIPE IS NO JOKE folks! I will report back shortly with accurate numbers and pictures, but I can tell you all right now, it's TRUE bolt-on HP if I ever saw it! I'm VERY happy! :woohoo:
#12566
Scott replied the topic: Re:New CC Racing 2-stage tuned pipe.
Good news ... always a better mouse trap just around the corner ... Zoom Zoom !
#12567
Moofy07 replied the topic: Re:New CC Racing 2-stage tuned pipe.
It is good to see another producer of the two stage pipes. I have one of Carmen's Need for Speed pipes and I will say the design really does add power. I don't have a dyno but the top end speed has increased dramatically on those boats I have tried it on. This style of pipe does make a difference.
I think it is along the same lines as the early (80s) Gp bike engines but improved on that with a modern twist.
Just some info for you.
#12569
Ozpulse replied the topic: Re:New CC Racing 2-stage tuned pipe.
Good to hear 2 stage pipes work so well! B)
Just about finished one for my 50cc, just got to find a real tight 1inch 90degree bend for the header.
It would be good to see comparison vids! ;)
#12570
If you can't find something in steel, try a plumbers shop and pick it up in copper.
Hope this helps.
#12571
Actually that would be perfect Moof' I only have room for the 90deg as it a continual taper!
Thanks! ;)
#12574
Mercury94 replied the topic: Re:New CC Racing 2-stage tuned pipe.
Two angles before center of pipe. I have Hansen pipes that are two stage.
#12735
<strong>earthsurfer wrote:</strong>Actually the engine side cone would be your DIVERGENT cone and YES 2 stage refers too this cone having TWO angles of divergence before the maximum diameter and rear Convergent cone attaches. ( BTW convergent cones can also have multiple angles too )
#12739
Time to create page: 0.124 seconds
