Engine dies when boat placed in water
e21stick created the topic: Engine dies when boat placed in water
I am running a clutch and water pump on my 60 inch cat, it idles great but when i place it in the water it will die.I have to remove plug and clear out cylinder ,rechoke it and then it will crank.
#12532
Scott replied the topic: Re:Engine dies when boat placed in water
<strong>e21stick wrote:</strong>
You first must diagnose WHAT and WHY it is dying ... know it's what your asking, but we are not there and you are.
When it dies, Is plug wet and engine flooded ?
Does engine get water in it from the cooling system of exhaust couplers causing it to die ?
Is engine idling once on water or dies upon acceleration ? If dies upon placing in water betcha water leaking in at exhaust as pump primes cooling system .... dies upon acceleration, carb setting too lean on low end. :blink:
#12533
marc replied the topic: Re:Engine dies when boat placed in water
Yeah, sounds like it getting in from the exhaust. Remove the cooling from the exhaust, just let the water go overboard to test. Take it from there. You might be injecting way too far up in the header? Hard to tell without more details, as Scott has already pointed out.
#12534
Time to create page: 0.243 seconds
