Dyno questions
Misty1977 created the topic: Dyno questions
Hi to all boaters. This is mostly intended for Scott or Marc but any bodies input is appreciated. We have been boating for about 3 years now, and in our quest for more power we have decided to build a dyno. Manufacturing of the mechanical components is not a problem for us as we have an engineering business. we just need some input from others who have been down the road as what is the best way to go? For starters, what is the better route, either inertia or brake? In other words, the most accurate and repetitive system to use? What are the pros and cons of either system? If anyone has built a dyno, it would be appreciated if they can advise what would be the best software available for these small engines. Any designs or ideas for the mechanics would help a great deal, as well as the most essential sensors required for example, weather stations,temperature, gas analyzer etc. Also, what is the most accurate tuned pipe software that anyone has come across? We would like to share as much info with the people out there. We are from South Africa and in the last 3 years we have taken the sport to new levels and many people here are constantly asking us for assistance to promote the sport! Many thanks. Misty. South Africa.
#12080
Scott replied the topic: Re:Dyno questions
Misty,
First off welcome to MGB :woohoo:
I am NOT qualified to give much dyno information due to not having one or ever building one ... That said :dry:
IMO a break type dyno is the best way to duplicate a somewhat close to actual load having the heat dynamics of the engine/pipe/spark plug be more real world stabilized.
Inertia types while very useful can only give you flash readings of data per rpm point as data is collected. At no point in a few second pull will engine be stabilized enough to give a solid reading on whats happening at any specific rpm point. Because the mass of the inertia dyno flywheel is so great it in a sense dampens the fine detail of hick ups in power where as a break dyno would show the discrepancy in greater detail allowing you too load engine at that point allowing tune changes to be made and view differences at that specific rpm.
This just my opinion ....
#12081
Misty1977 replied the topic: Re:Dyno questions
Hi Scott.
Thanks for the quick response. I have been following MGB for quite some time, actually its been a good information tool! I agree with your opinion regarding the dynos 100%. Only problem is that there is not much resources for small engine dynos here in SA. Went to go see a group of dyno specialists today and unfortunately I was dissapointed once again not to have any luck? Would you possible not know who I could contact in the States who could assist us? I have been through google but there are many to choose from???
On another note, Oil content? I have been running 16:1 for quite sometime now? i've read on other posts more oil = more power and better compression seal but heres whats odd to me. Im using motul 800 2T, and at that ratio it seems like too much oil because Ive noticed carbon build up and i just cant get the plugs to burn that tan brown colour now matter how rich or lean i go with the needle settings? Last Sunday, decided to blend a 30:1 ratio, off to the dam, and seemed to get alot less carbon with a cleaner, crisper, sounding engine as well as that tan brown color on the spark plug. People tell me 13:1 is even better? Motul bottle says 50;1 for racing and 66;1 for general use, so Im puzzeled? Do u think Oil ratio And the amount of watercooling go hand in hand here?
Though id post a photo of a Fully modded Cy26 that we actually broke through the casting in thin errors that we repaired with steel putty. Runs great at 6000ft above sea level with a max speed record of 92km/h in a monohull. Take note of the water jacket that is bolted with the same bolts hat hold the jug down. Cant tell u how many times I have dunk it and it just keeps goin...
#12085
marc replied the topic: Re:Dyno questions
Here are a few sites for dynos and information:
www.land-and-sea.com/
www.trik-dyno.com/
www.tdkmotorsports.com/dyno.htm
I have a dyno that I built myself a few years back. It is an inertia dyno that utilizes a modified Eagletree Data Logger (some mods done to it by Eagletree for the application) and software that I did myself with assistance from Mike Hoffmeister (used to be with M&D engines). I also picked up a lot of info from the TDK Motorsports website above. Personally I prefer the inertia dynos because of the way we ramp up the engine rather than choke it with a load. I feel it more realistically represents real-life conditions, but that is just my own personal opinion...and we all know what they say about opinions!!! :D I use my dyno for personal use only..to compare engine mods and sometimes to compare different manufacturers' engines. It has been compared with the factory results Zenoah gets on stock engines, as well as with a few other dynos from engine builders...I must say it's pretty reliable and accurate, even though I don't have the weather station on it (manual entry of parameters in software). To do back to back comparisons though, the weather station isn't really that important for me. The Eagletree system logs 10 samples per second for a pretty good sampling rate. Another good data logger to get if building your own dyno is the Performance Trends Datamite. It's not too expensive and has many available options and sensors. On mine I use Exhaust temp EGT, Head temp, ambient temp, and RPM sensor.
As for your oil and carbon buildup question...I've noticed that with some brands of oils, even synthetics... I tried Klotz with Castor: terrible, Amzoil Dominator: not too bad, Castrol Syntec: not too bad, Honda HP2: very good, and now will be trying Cool Power Blue this year... I've heard that this oil leaves no buildup at all, even in the pipe. The HP2 never left buildup in the engine, but it did accumulate in the pipe. So far though it's been the best synthetic I've used. As for the conventional oils, well the few I've tried all left major carbon buildup at the mixture I use, which is 16:1.
#12086
lohring replied the topic: Re:Dyno questions
All our small engine development has been on an inertial dyno. Though it has limitations as Scott points out, it has huge advantages. The most important is that you can get 50 complete power graphs in an afternoon. We also have Stuska dynos for larger engines, and they are much more time consuming. We built our dyno because we wanted to duplicate the conditions of a SAW run, which it does. I still believe the information we get is very applicable to heat racing as well. An article describing the dyno's construction can be found in Model Engine Builder, issue 15. A copy can be purchased at www.modelenginebuilder.com/subscribe1.htm I can send you a spreadsheet we used in the flywheel design. It gives stresses and estimated run up time for different engines with different size flywheels.
We have run the dyno with a variety of gasoline engines from 2 to 12 hp and had no problems. We melted pistons on several nitro engines, however. I recommend a smaller flywheel for that testing. We used a Performance Trends data logger. It's been bulletproof, unlike the Eagle Tree that we run in all our on water tests. The price reflects the difference. It comes with excellent dyno software. However the instructions take time to master. See performancetrends.com/dtm-dyno.htm We only use the dyno rpm sensor as the ignition sensor is unreliable at high rpm. We also manually input weather data. Exhaust gas temperature would also be valuable, but we seldom use it.
Articles on our testing are available on this site:
www.modelgasboats.com/Magazine..._Record_Engine/
www.modelgasboats.com/Magazine...icles/Gasoline/
www.modelgasboats.com/Magazine...es/Tuned_Pipes/
www.modelgasboats.com/Magazine...Pipes_-_Part_2/
#12088
The following user(s) said Thank You: Misty1977
Misty1977 replied the topic: Re: Dyno questions
Hi Martin Lohring. We have finally decided to go ahead and manufacture an inertia dyno machine for our engine and pipe testing. Quite a while back in a previous post you said that you would send me a spreadsheet for the roller weight design for various engines and run up times. It would be greatly appreciated if you could send me that info to This email address is being protected from spambots. You need JavaScript enabled to view it. for the attention of Misty. another question? What grade material would you advise for the roller at those rpms? En19T or En24T or would En9 be sufficient?
Many thanks
Misty
South Africa
#18699
Ksheren replied the topic: Re: Dyno questions
Doug you have a pm.
Kevin
#18797
Thanks Doug. Taking the provincial title in 2011 was not too difficult seeing that I had a excellent pitman who would start that puppy up on the first pull and off I would go for 20 minutes (heat race duration)without any troubles. I think I only dunked the boat once the whole season. I was running against two quickdraws which were the biggest competition even thou the ts reed 29.5 seemed to have a bit more legs especially out the corners. The other advantage is that the competition would regularly fall out and would have to go rescue their boats, seeing as it is endurance you can rescue your boat and continue, so I would take full advantage and make lap after lap. I was making roughly 55 laps per 20 minute heat which is actually very good.
The national title on the other hand was a little more difficult. Was racing in 70 km/h wind gusts and the water was very rough. the competition was also tight with the biggest competition being a very good and well known boater who runs an exotic j&g quickdraw hybrid which is fast and well setup for rough water. after the first day of racing, he was 7 laps ahead of me. On the second day luck fell on my side and his engine was not performing where as the ts reed 29.5 didnt miss a beat. I managed to catch up the 7 laps that I was behind and still managed to make up another 20 laps ahead of the guy in second place. Yup you heard it, 20 Laps! A bit of luck, good driving and a reliable engine helped me take the SA title for 2011. Thanks Doug.
Doug, still waiting for your reply that I sent to you via email in connection with your performance trends software. really keen on taking it off your hands. Definately need to build a dyno this year.
Thanks
Misty
Second boat from the right next to the red cat is the winning formula
#18852
