Ryobi 30cc
chfrowland created the topic: Ryobi 30cc
HI
I have come across a Ryobi 30cc weed eater. I am planning on using it in a 48" very deep 'V'.
What would you guys recommend for a carb?
this project is from scratch, so I think it will take a while.
Kind regards
#11454
marc replied the topic: Re:Ryobi 30cc
A carburetor that was always very popular with modified weedeater engines was the Walbro WA-167. If you can find one, I would try it. Scott probably knows some others that will work well also.
#11456
Scott replied the topic: Re:Ryobi 30cc
Honestly ... use the stock carb on the engine for now.
It would be pretty safe to say that Ryobi weed wackers are NOT high performance and simply adding a bigger carb in not going to wake it up to any degree you might see at this point. actually you have a greater chance of engine running worse if the after market carb fitted is not calibrated to work within the displacement CC's of the engine.
Spend your time, effort and money on building your new boat on just that ... the boat.
Once you get it all sorted out and running, address the engine performance issue then
** Yes the WA-167 is an excellent choice ( The OEM carb of the older Zenoah G230 engines )
Regards,
Scott
#11463
chfrowland replied the topic: Re:Ryobi 30cc
Great. Thanks.
I am in Australia at the moment. Going to have a look online now.
Ok.
Thank you Scott. It is better to have something that floats to start off with.
thanks again.
regards
Dug
#11465
martno1fan replied the topic: Re:Ryobi 30cc
Geta Walbro wa 167 carb it makes a night and day difference to a stock weedy,i gained a good 5 mph from doing that alone.Finding one may prove difficult though.
Mart
#11684
Moofy07 replied the topic: Re:Ryobi 30cc
Hi,
Yes,keep working on the hull, that advice is excellent. In the meantime I have a WA 167, albeit a modded one. If it is what you require send me an email and I will try to dig it up. I am in Bundaberg, Qld.
Hope this helps. :)
#11685
Hi
I have encountered another problem with the motor. I had dismantled it to clean it up and put it back together. It worked fine, I then replaced the spring that holds the choke open or half, not the motor will not run for more than a few seconds. Any ideas?
Moofy07, Thank you for the offer, Lets see if it cooperates.
Ps. I noticed that it is has a half crank. Is this normal/ OK for a boat?
#11712
From what I have seen an awful lot of weedy motors are half cranks and yes you can use them in boats with no problems.
#11713
chfrowland wrote:
Remove carb again and make sure all intake maifold gaskets are positioned and installed correctly.
* if you went into carb ? .... make sure it is reassembled correctly.
4 screw cover (Metering side) gasket against carb body, then diaphragn, then cover.
1 screw cover (Pump side) diaphragm against carb body, then gasket, then cover.
#11715
