RE: Zenoah Motor Question
usttraw created the topic: Zenoah Motor Question
Ok... I'm new again... so my technical lingo in not up to speed. I have a 2009 CC Pro Mod purchased from the dock (Carlo confirmed it) that had as listed couple of weekends use. Visually it's mint. Question... when holding the collet, you can move the shaft in and out a little. Is this type of play normal? Thanks!!!!
#11281
GHill replied the topic: RE: Zenoah Motor Question
Yes you need the end play, not sure how much but i know it is to be there.
Graham
#11282
Scott replied the topic: RE: Zenoah Motor Question
Yep, .020" or so of In and out is typical.
#11283
marc replied the topic: RE: Zenoah Motor Question
As Scott said...about 10-20 thou is normal...when you don't feel any end play at all is when you start to look closer at things!!! Using the wrong bearings and or gaskets can cause the endplay to be insufficient and cause problems. :)
#11285
usttraw replied the topic: RE: Zenoah Motor Question
Ok... I feel better now! Thanks!
PS> Marc, check out my XXX build status on the dock... getting closer!
#11312
