RE: rcmk base gasket size?
damian created the topic: rcmk base gasket size?
Hi Guys can anyone tell me what thickness the base gasket on an rcmk evo rear ex is ?
Thanks
Damian
#11057
Scott replied the topic: RE: rcmk base gasket size?
Compressed once tightened down seeing @ .012"
#11058
damian replied the topic: RE: rcmk base gasket size?
Thanks scott,
I am currently modifying the rear ex evo for my sport hydro, It runs strong with what I have already done with timings and transfers, wondering if I should drop the deck height a wee bit? the ex is at 184 and intake is 157, you know how it is , no mater how fast you go you always want to go faster :grin:
Damian
#11066
Mercury94 replied the topic: RE: rcmk base gasket size?
What about a +1mm stroker crank? Would that give more compression and displacement?
#11067
If your RZ is anything like the half dozen or so I have been into thus far, they come decked already pretty tight at @ .020" from the factory.
Lowering decking further without re cutting piston dome your going to be to tight on squish. * Also going lower is going to extend the intake duration more which being @ 157 now is going to cost you torque, tho rpm will be even higher.
The numbers your at now 184/157 is IMO pretty spot on for a race duty boat .... Play with pipes of different volume and cone angles :good: .. you will be mildly surprised on the power band changes that will be discovered.
#11071
Thanks Scott,
These evos seem to have a bunch of torque,will play with pipe more and see what I can get out of it,once again thanks, your advice is most appreciated.
Damian
#11072
