Piston ring gap
50 stowe created the topic: Piston ring gap
On a new zen or a new evo motor what should the ring gap be?
#10367
Scott replied the topic: RE: Piston ring gap
(Metric) ... End Gap (mm) 0.05~0.25 on G260/231 engines. RCMK should be the same.
Max Limit 0.5 (mm)
All the spec can found within the operators manual found here: rds.yahoo.com/_ylt=A0oGklmOZ2B...enownersman.pdf
#10369
50 stowe replied the topic: RE: Piston ring gap
Thanks, Running a evo top with a zen piston just want to be sure. Is there any problem doing this?
#10379
No problem doing so ... a good idea tho to undercut diameter .002" above and below ring as is customary with modified Zenoahs.
#10380
It is a mod piston, Just trying to use up old stock before i move over to all rcmk motors. Working on a self mod evo cylinder. Do i have to widen the intake and exhaust like the zen?
#10382
May I suggest if wanting to explore tuning tricks for the EVO cylinders you start a specific thread on said subject ;)
#10447
marc replied the topic: RE: Piston ring gap
BTW, both the Operating Manuals and the Maintenance Specs manuals are available on this site in the Resources section. There's also a troubleshooting guide. Will load a lot faster and easier than that external link. :)
#10450
