Floatation
Ilias_Arkoudaris created the topic: Floatation
Hello, I would like to make a question.What kind of adhesive do you use to glue the floatation foam on the hull?? I am really confused about this thing..could you please help me?
#938
marc replied the topic: Re: Floatation
I never glue the foam in the hulls. Here we commonly use "pool noodles" for floatation in our boats. In many cases we just push them in and not even attach them, but to be safer simply use "zip ties" or "tie wraps" to tie them to the stringers of the hull. That way if the hull separates in a hard crash or flip, the foam will keep the stringers and what ever is tied to them afloat. So that should save your motor, radio gear etc...basically everything important.
Tying the floatation in rather than gluing it allows you to replace it if need be. The foam will sometimes suck in water and I usually pull it out after a season and replace with new foam.
Hope this helps!
#939
Ilias_Arkoudaris replied the topic: Re: Floatation
Thank you Marc,basically the problem is that the stringers,don't have any openings,or holes,so that I can use zip ties,anyway,I will figure out something..really appreciate your help
#940
You can simply drill the stringer to allow for a few tie wraps.
#941
Ed Sidders replied the topic: Re: Floatation
You can simply drill the stringer to allow for a few tie wraps. Just don't forget to waterproof the bare wood that will be exposed in the holes that you drilled
#942
Scott replied the topic: Re: Floatation
I use double stick velcro ..... Works fine and stays put when boat does an unexpected tumble :P
#943
Good idea Scott will it work on my boat ?? My Tumbles are EXPECTED LOL Ed
#944
WPERRY38 replied the topic: Re: Floatation
? "pool noodles where do you buy them?
[/quote]
#945
You can get pool noodles in many stores including pool supply stores and Walmarts among others. They are available in tube form and also in flat board shape which can come in handy for hatches and such.
#946
hello, I finally used this stuff (www.nelcoproducts.com/shopping...?pid=150&cid=48) ,which i attached them on the inside of the hull,and with tie wraps the job is done,I believe that this is the best way..
#947
Time to create page: 0.453 seconds
