Dremel Bits for Triming and Cutting
usttraw created the topic: Dremel Bits for Triming and Cutting
Need some help here...
What type of bit's are you using to trim and/or create openings in fiberglass hulls...
Also, for the flex shaft, what cutter is used?
Thanks!!
Aaron
#9185
marc replied the topic: Re:Dremel Bits for Triming and Cutting
I use just a plain cutoff wheel on the Dremel to cut cables.
For trimming Fiberglass I use a Rotozip 1/8" cutter in the Dremel...works great. Put the finishing touches on with a Drum sander on the Dremel. :drinks:
#9187
usttraw replied the topic: Re:Dremel Bits for Triming and Cutting
Thanks Marc!
Drilling holes for hardware and cutting all the air vents in the XXX this weekend :drinks:
#9190
