Delta force off shore electrics 44" mono will not work with gas or nitro
davidkelly created the topic: Delta force off shore electrics 44" mono will not work with gas or nitro
Hi every one how has helped out on this mater as far
as Delta force boat go I really appreciate it cool watching
the videos you put on and all the other info I contacted
off shore electrics and he does not have any right now he could
get one in for me for a gas set up but it could take up to or over a year to get it he not sure on that ?
so I was wondering if any one nows of any ones else how might carry
then in the us he tells me the one he has in stock right know does not have the engine rails to handle gas or nitro .
thanks for your time
David
#8988
Dicko replied the topic: Re:Delta force off shore electrics 44" mono will not work with gas or nitro
If you look on the Delta Force website they have a link to WA hobbies (or something similar) in Hong Kong. It would probably be easiest to contact them & see what their shipping rates are like. I know the guys in Brisbane import their Delta Force hulls from OS so it shouldn't be too bad.
#8990
#8991
BillSOCAL replied the topic: Re:Delta force off shore electrics 44" mono will not work with gas or nitro
Both of mine came without rails. You install them yourself. In my case Paul Pachmayer did my builds and he put the rails in. That was for both the FE and gas versions.
#9001
Not true, if you order it for gas it should come with rails. Have a look on their website, all theur boats designed for Gas come with rails. If you order an electric hull it won't come with rails. The hulls I've seen have come with rails as standard.
www.deltaforce-hk.com/df/sniper44.html
www.deltaforce-hk.com/df/df.html
#9002
All I can tell you is that neither one of mine had rails. Maybe they were ordered without them, that I cannot tell you since I did not place the original order. Regardless, it is not that big of a deal to install the rails.
#9053
Time to create page: 0.825 seconds
