Speedmaster Rudder Pickups; Big Enough?
Tropheus created the topic: Speedmaster Rudder Pickups; Big Enough?
I have heard a lot of recommendations to drill out the rudder pickups on the Speedmaster rudders. Is that necessary with a dual rudder pickup? One to the engine and the other to the exhaust. Do I risk overheating an engine using the rudder as it came?
#8833
Scott replied the topic: Re:Speedmaster Rudder Pickups; Big Enough?
Never needed too yet .... always had plenty of water flow and cooling using SM rudders.
#8835
Moofy07 replied the topic: Re:Speedmaster Rudder Pickups; Big Enough?
Hi,
I have never experienced any waterflow problems with the Speedmaster Rudders. If you are worried about this, just try other things like adding a second pickup off the transom. I have never really liked the ones that hang behind the prop, they tend to throw a lot of air with the water through the pickup. This might be ok if going through just the exhaust but not around the cylinder which as you know needs a constant water flow.
Hope this helps
Cya. Graeme
#8836
marc replied the topic: Re:Speedmaster Rudder Pickups; Big Enough?
They usually work fine right out of the bag. I have drilled some, and other I didn't. Never really had a problem either way. With the single pickups I usually drill them just for piece of mind. The duals I run as-is.
#8842
Tropheus replied the topic: Re:Speedmaster Rudder Pickups; Big Enough?
Thanks for the responses. Just looking for piece of mind before tossing in a new build with new engine in the pond. The rudder is set 2 3/4 right of the strut so there shouldn't be any air to contend with. Never been a fan of placing the rudder directly behind the prop.
#8844
Time to create page: 0.687 seconds
