Running Lean vrs Running Rich
ewaho created the topic: Running Lean vrs Running Rich
When using a third channel, is it better to run on the lean or rich side?
What's the effect of both?
#849
Scott replied the topic: Re: Running Lean vrs Running Rich
Lean is BAD!! .... fries glow plugs, can lead to detonation and piston siezures.
Richer is GOOD ! .... Above does not happen and engine typically has better torque too.
#850
Ed Sidders replied the topic: Re: Running Lean vrs Running Rich
Scott
You must be getting old or something . You said a big mouthful in two lines.
Will give you a big Amen Ed
#851
Time to create page: 0.385 seconds
