floatation materials
wally j created the topic: floatation materials
will spray foam insulation work on a monohull if not what other materials will new to hobby
#8333
Moofy07 replied the topic: Re:floatation materials
Hi,
I have found those long pool noodles work well, just keep the fuel away from it. They can easily be cut up or even shaped to suit your requirements.:bye:
#8334
Hi again,
Spray foam will work also but it can be pretty permanent ie. you will have to cut it out to remove it
#8335
Scott replied the topic: Re:floatation materials
Pool noodles, Foam pipe insulation, Wall board foam, Styrofoam packing in a SEALED zip lock bag, Empty water bottles etc ....
Styro & gas don't like each other, so you CAN'T use block Styrofoam by itself unless in a sealed wrapping of some sort :ohmy:
#8336
marc replied the topic: Re:floatation materials
Spray foam is not good. It will permanently soak up water and weigh down the hull, not to mention make it rot over time. Pool noodles, pipe insulation, etc as Scott noted is the way to go. Replace them if they get waterlogged over time. It is a good idea to tie them to the stringers, that way if the deck of the boat breaks off, the noodles will stay attached to all the $$$ parts!
#8337
wally j replied the topic: Re:floatation materials
thank you for all the help regarding floatation materials your help was greatly appreciated had no idea what pool noodles were looked it up on line i felt so stupid wallyj
#8338
Time to create page: 0.183 seconds
