stryker hydro set up
blazincat created the topic: stryker hydro set up
I am a little new to this site but my question is I have a stryker hydro gen2 that I got on a trade and I am not sure how the set up is supposed to be. I have a mod motor in it from hmetalh and I cant get the boat to move,the prop is a 6717 with a 420 pitch and the strut height from the bottom of the drive to the bottom of the boat is an 1and a half inch can anyone tell me if this sounds right since i am used to cats and new to the hydro and the prop is a 3 blade thanks D:)
#8172
marc replied the topic: Re:stryker hydro set up
Follow the setup of the Insane Gen2 Sport Hydro... Here is a link: www.insaneboats.com/images/sto.../hydro2diag.pdf
#8189
Steve Seebold replied the topic: Re:stryker hydro set up
Contact Ron Buck at This email address is being protected from spambots. You need JavaScript enabled to view it.. He was in on the design of the boat and should have set up instructions for it.
#8201
Tropheus replied the topic: Re:stryker hydro set up
You can't get the boat to move. I am assuming it starts and you put it in the water and it just cavitates. Prop sounds right and the strut depth is ok. Sometimes you have to give it a good throw and work it on plane. If you just set a hydro in the water and hit the throtle, the prop will just spin and not grab---cavitation.
#8305
Time to create page: 1.027 seconds
