short Flex cable..
gc9n created the topic: short Flex cable..
This is my Second problem i have with the boat..
i recently added a water pump because i wanted to use a Clutch ,i successfully added the pump/clutch. Now the problem is that the Flex Cable is longer and also the second end (engine side) have to be square and it is round! So i purchased an adapter photo below..
After that i had to Solder it .. i tried to solder it with everything you can imagine even with wire soldering.. but everything was disaster..
Now i found a flex cable from a guy from Australia ebay.. but the smallest was too long for me.. do you guys have any idea what should i do?????
#7719
gc9n replied the topic: Re:short Flex cable..
Now i found a flex cable with both two square ends from a guy from Australia ebay.. but the smallest was too long for me.. do you guys have any idea what should i do?????
#7720
martno1fan replied the topic: Re:short Flex cable..
Just an idea but why not change to a round collet and round cable :)
#7725
cause that type of clutch is for square end only..
Something else.. could i change the propeller end strut with something else that requires only round flex cable, and put the square end to the clutch side
#7726
marc replied the topic: Re:short Flex cable..
You might want to try Loctite 680 (bearing retaining fluid) on the adapter. A lot of guys in Europe use it for ferules on flex cables. Apparently it works great.
#7727
the flex cable length are in standart dimensions?
for example 390mm 560mm etc..
Could i find somewhere a custom dimension 1/4 flex cable?
#7728
gc9n wrote:
Thats why i allways use round collets and cables no need to ever worry about soldering ,just cut to length and fit it.
Mart
#7730
Scott replied the topic: Re:short Flex cable..
Soldering cables is a tricky one, Low grade SILVER solder is required. Sta-bright 5% at minimum, 15% about maximum.
A proper silver flux also required
If you have a new cable & Square end ? .... I would be willing to do it for you, just cover shipping :drinks:
** Can't solder a cable & square adaptor once the wrong flux and solder have been tried :ohmy:
#7731
Warehouse Hobbies will do custom cables for you. 9x4br.64n2f.servertrust.com/Pr...USTOMSOLDERLESS
#7733
Marcs idea about using the loctite retaining compound also works well.You must clean the cable well first though ,maybe use brake cleaning fluid or similar to remove any grease dirt etc.
Mart
#7736
Time to create page: 0.716 seconds
