stinger rudder set up
lightningphil created the topic: stinger rudder set up
hi all
im planning on getting a stinger drive for my new hull that i have.
the stinger is 105 mm to the drive dog.
the rudder i plann on getting is 150 mm to the leading edge of the blade of rudder
will this set up be ok ????????
regards phil
#7410
marc replied the topic: Re:stinger rudder set up
That sounds just about perfect to me. It should put the leading edge of the rudder just about even or very close to the trailing edge of the prop. That's typically a good relation between prop and rudder on a mono. :)
#7411
Time to create page: 0.725 seconds
