Grease for flex drive cable
buontinh created the topic: Grease for flex drive cable
Hi all,
I'm new to RC boat and was wondering if I can use this type of grease from Autozone to grease the flex cable. The stuff is very sticky and so make the prop hard to turn by hand.
Thanks
www.autozone.com/autozone/cata...eURLList=%5B%5D
#7353
ken0276 replied the topic: Re:Grease for flex drive cable
I'm using Castrol full synthetic grease from Autozone, it works great.
#7356
marc replied the topic: Re:Grease for flex drive cable
Any good waterproof grease should work fine. Some last longer than others, but if you do good pre and after run maintenance you should not have problems with whatever grease you use, as long as it's good quality and waterproof. I personally prefer the one that CC Racing sells...lasts a whole day easy.
#7359
Time to create page: 0.176 seconds
