How can you tell when your on pipe?
ottie44 created the topic: How can you tell when your on pipe?
With a Nitro it's ez but is there a quick way to tell if your staying on pipe with a gas engine?
#7297
ottie44 replied the topic: Re:How can you tell when your on pipe?
Does anyone make a add on stinger that will quiet down the noise, without killing the power?
#7299
marc replied the topic: Re:How can you tell when your on pipe?
You can tell just as well with a gas boat if you come off pipe, it will lose significant power.
For a good add-on muffler check with Mike Tyson. This email address is being protected from spambots. You need JavaScript enabled to view it.
#7300
thx Marc I'm not sure if I have ever been on pipe with my gas. Stock engine would run 52 mph on a Stalker Radar gun. Still breaking in the Mod engine. With nitro I go by sound and rpms. If its a little fat it would not get on pipe, to lean and it would bog in the corners! With gas I have speed and torque from just above idle to wide open.
#7301
Gas engines are very torquy and will run surprisingly well even with less than optimal pipe settings, but if you get the pipe tuned just right and slowly accelerate you will here it coming on. It is much more noticeable with boats that put more load on engines, such as hydros. If they come off pipe you know in a hurry!
#7302
With the stock motor there was a sweet spot, when it kicked in the boat would wheelie. Still looking for that from the Mod. Running 16:1 Octura X470 and 12 1/2 inches on the pipe. It runs strong but still waiting for the big burst of speed! Hydro?? lol I know REAL MEN DON"T TURN LEFT!!!!!!!! Last rigger I had was one of the first RoadRunners with an OPS .67 and Irwin quiet pipe. That's how long I have been out of the sport, have things ever changed!
#7303
INEEDSPOTS replied the topic: Re:How can you tell when your on pipe?
What pipe are you using? How are you measuring? If in a straight line from exhaust port to weld (if a 0 band)..12.5 is pretty long and probably why it doesnt hit the pipe hard.
Heres a quick video of my whiplash showing how hard it hits the pipe when stabbing the throttle from a little over an idle
tinypic.com/r/2wf7b11/3
#7309
90 degree 3 in. offset header, BH Hanson pipe with a 1 " band. Stayed a little long to keep some bottom end torque. Measuring from the port to the band.
#7310
Scott replied the topic: Re:How can you tell when your on pipe?
One major contributor too being unaware of a gas engine coming on or perceiving it doing so are a heavy prop load. As mentioned having the torque we do, engine will transition pass the this point relatively seamlessly.
Prop down some and it can become quite obvious :dance2:
* It is the point where the rpm will jump up and engine seems to suddenly wake up and get perky.
Those boat / engine set ups that are biased towards broad rpm use seldom seem to come on the pipe, but if pipe length is close to being right actually does. Set ups in the race boats where props tend to be smaller and pipes shorter, the RUSH of power coming on the pipe is very noticeable.
#7311
Fielies replied the topic: Re:How can you tell when your on pipe?
I am rtunning 92mph.do you think i am on the pipe yet?.
#7312
Time to create page: 0.604 seconds
