clutch or no clutch..
gc9n created the topic: clutch or no clutch..
Hello there!!
i am new to the Boat world
I wanted to ask the guru of the forum ..
Is it better to run an rc gas boat with Clutch? Or without Clutch??...
I ask because if the boat has no clutch is a little difficult to handle; if it spins the propeller constant;
Sure I understand that a boat with clutch will loose top end because i will add components to the drive train
PS the place that i will run the boat is only sea
Thank you
#6969
marc replied the topic: Re:clutch or no clutch..
This all boils down to user preference. In general racers will not use clutches because of extra losses in the drivetrain. Many sport boaters will opt for a clutch because of it's ease of use...ie: easier to launch, possibility to idle in position, etc...
The clutch will however require a water pump be installed in the boat for cooling the engine when the boat is idling (not moving).
Personally, for sport use I find a boat is much more fun with a clutch. :drinks:
#6970
gc9n replied the topic: Re:clutch or no clutch..
Thanks Marc for quick reply.
as i am an owner of a baja 5b i have all the required part for a clutch but i need this one
where can i find this part???
Also the water pump that you are saying where can i find it?
And something last if i add a clutch , will i have to short the axle??
Thanks in advance
#6971
You can get the complete clutch from Oneil Brothers for $60...not really worth looking for parts: www.oneillbrothers.com/rcboat/...info/clutch.htm
Here is a link to the pump: www.oneillbrothers.com/rcboat//pumps.htm
Warehouse Hobbies also carry a full line of clutch parts and pumps... www.whobbies.com
#6973
Time to create page: 0.140 seconds
