please help
bigricktheman created the topic: please help
hi everybody,i have a boat -outrigger,with a ops 40 engine,,the problem is that if there is any fuel left in the tank it leaks out from the header port,and it is very hard to start,i mean all of it leaks out,any help would help out,,thanks rick
#6945
marc replied the topic: Re:please help
Post a pic if you can. Not sure I understand completely. Is your header port lower than the tank?
#6949
bigricktheman replied the topic: Re:please help
no the tank and header port are about the same hight,it comes out of the exhaust port where the header slips on to at the motor
#6952
mitchesx replied the topic: Re:please help
I have the same problem with my nitro boats (the couple I have left) if gravity takes over and runs the fuel out of the tank, into the carb, the sleeve/crankcase, and draining out the exhaust. Most times it could be that the tank is higher than the motor, back pressure, a bad tank setup, or what ever. I usually clip the fuel line (close it off) until I'm ready to start it, and then I let a little fuel thru and then pinch off the line with my fingers while I start it. Otherwise - I have the same mess to clean up that you do, and starting is impossible with a flooded motor. Once the motor is running and the needle is set properly; mine run fine, I just have to remember to clamp off the fuel line when I bring the boat in. Gas is sooooo much easier!!! :blush:
#6955
i guess i will just clamp the fuel line until it starts and make sure the tank is empty,thanks for your input,yes it does help..does your boats run ok once they start again thank you rick
#6957
On a lot of nitro boats, the goal is to get the tank higher or at least close to the same height as the carburetor to help get fuel to the carb. Exhaust pressure alone often isn't enough to ensure proper fuel delivery and so the tank is installed a bit higher. We don't do this with gas boats because the carburetors we use have their own internal pump, unlike most of the nitro carburetors.
* as suggested, just pinch the fuel line, it is common practice with nitros.
#6963
