project
sandjperformance created the topic: project
my 36 inch hydro converted 2 gas have not runn it yet motor is a 23cc what do u guys think
#6557
sandjperformance replied the topic: Re:project
my ? is what do u guys think
#6560
marc replied the topic: Re:project
Hull seems a bit small for gas, but if it runs, it will be fast!!!
#6561
i will take a pix of the hull from far so u can c the whole boat hope it runs
#6562
this is the hull
#6563
Scott replied the topic: Re:project
Seeing that perspective .... engine is WAY too far back.
The drive cable collet of engine should be at @ the end of the sponsons ride surface with engine completely forward of that position.
JMO :blush:
#6564
CPMODS replied the topic: Re:project
:ohmy: wow,thats a ugly boat!!!...lol
#6565
so were should the motor be thanks for ur help
#6566
sandjperformance wrote:
It was already said ... The drive cable collet of engine should be at @ the end of the sponsons ride surface with engine completely forward of that position.
Attached an image of a typical engine position used in Gas Sport Hydros.
The Sponsons TRAILING edge is just behind the "3 and 9" numbers where the outside edge of sponson turns inward.
* Location should be about where your "DUMMY" engine is at :ohmy:
#6567
scott thanks for ur help i would like 2 no if u have ever run this type of hydro i have not i just started the hobbie got this boat destroyed and turned it into a project.
#6569
