Exhaust coupler
BIG9775 created the topic: Exhaust coupler
I need a better exhaust coupler for my 56' Apache hull.I purchased some heater hose from NAPA auto parts,but it doesn't last very long and smoke starts coming from the hull after a few laps around the pond.:ohmy: What brand is the best for heat and last the longest? :?
#6253
marc replied the topic: Re:Exhaust coupler
Most gas boaters do not use couplers...pipe systems designed for gas are usually made entirely of steel, aluminum or stainless steel. I have seen guys use couplers on occasion though, and the only thing that will resist to the heat generated by gas engines is TEFLON couplers. I remember seeing Brian Watts using them, so check with them.
Found a link to them on their site. 7/8" and 1" ID teflon couplers on this page:
www.rocketcityracing.com/produ...y_id=149&page=2
#6254
BIG9775 replied the topic: Re:Exhaust coupler
I have a CC racing 2 inch aluminum band pipe,which is not long enough to exit through the transom and there is a small gap between the end of the pipe and a piece of aluminum that was machined by CC racing.I will check rocketcityracing site.Thanks Marc!
#6255
OH ok, I see...then the 1/2" ID might be what you need...anyway they have 2 pages with couplers on RCR website...just make sure you go with the Teflon. :)
#6256
Got it !:) Thanks for your help.:dance4:
#6258
