Carbon Fiber Stryker Video!!!!
gforce created the topic: Carbon Fiber Stryker Video!!!!
Heres some video of my stryker. Its got a stock Qd25 and its running an H50 prop. I havent started twisting the needles yet I am still sorting out the setup..
#6143
CPMODS replied the topic: Re:Carbon Fiber Stryker Video!!!!
Cool garry!!
#6146
marc replied the topic: Re:Carbon Fiber Stryker Video!!!!
Cool! :) Cowl is tightening it up a lot!
#6151
gforce replied the topic: Re:Carbon Fiber Stryker Video!!!!
marc wrote:
what do u mean???
#6152
Tahoe1970 replied the topic: Re:Carbon Fiber Stryker Video!!!!
gforce wrote:
Gary , Marc means that the boat is more stable with the down force from the cowl at speed. (Runs a bit more planted to the water)
#6155
yeah but its a pig with the cowl.
#6156
You just have to fine tune it with the cowl on! :) I was just pointing out how noticeable a difference it makes running with the cowl on. Thus tuning with cowl off is worthless unless you will be racing it that way (as in SAW runs). I think you have a winning combo there, it just needs a little bit of tweaking... don't give up!
#6161
marc wrote:
Thanks Marc. I'm not a racer. I race the GPS. I have been running the boat mostly without the cowling. At first the carbon fiber was bolcking the signal from the radio and glitching. I driiled a small hole in the cowling so I can pass the antenna through. the glitch went away. It looks real good with the top but I think the boat runs better without. At least with my set up so far it does. Thanks for the help, Keep it comming I'm thirsty for knowlage.
#6163
Well, if you are looking for all out speed and not heat racing, then WITHOUT the cowl is the way to go...will run looser and gets much more cool air to the engine. :)
#6166
Time to create page: 0.137 seconds
