reverse pullstarter kit from bonzi 2nd one broken in the same place
wayneuk01 replied the topic: Re:reverse pullstarter kit from bonzi 2nd one broken in the same place
bonzisports.com/catalogue/prod...products_id=428
what i have is twin bz4 ultra's
:dash: a quote from there site Why would you ever want to sacrifice quality and strength for your boat?:dash:
#6138
marc replied the topic: Re:reverse pullstarter kit from bonzi 2nd one broken in the same place
Looks like a WAY too complicated design if you ask me. Hopefully they can work with you on getting this to work, or a refund of some sort.
Did you see the MHZ kit...a lot simpler. www.modelgasboats.com/Magazine...HZ_Reverse_Kit/
Maybe you could get the started end of the kit only from MHZ? The complete kit is now $398.00 not including engine.
#6140
HOOTERS racing 307 replied the topic: Re:reverse pullstarter kit from bonzi 2nd one broken in the same place
have a look on www.sonicracingaustralia.com none of this gear drivein junk
cheers
#6148
Looks like you can purchase the starter only from Sonic too...that could be an economical solution to your problem there!
#6149
Ive spoken to danny @ sonicracing his reverse starters will not fit the mounts the boat has so it would mean redoing it ...Also just got off the phone to bonzi £13 for a 15 min call wont be using the mobile again to ring the usa!Apparently the part is billet but looks cast to me where it has broken is this normal when billet breaks & They have previousley made a bracket that connects to the cylinder to help stop vibrations making this part fail but ive to wait & see if i get a replacement as the owner is away.. My only other idea is a pully & starter handle & rope & try starting it seagull style has any one tried this if you have a pully could you try it for me ..Ive had enough of it sitting on the side in bits allready its only been 3 days but thats 3 days to long for me ..I dont want a starter with a 12v battery as its more for me to lug around & even more cost
#6167
martno1fan replied the topic: Re:reverse pullstarter kit from bonzi 2nd one broken in the same place
That sucks mate i have to agree though what a complicated setup :( ,if i were you id ditch it get a refund and buy an electric starter and use a pulley to start them.
#6202
:clapping: Cool got a replacement on its way with a support bracket to cut down the vibrations just had to pay the shipping ..should it fail again i will have to go the other route with pully's a 12 v battery & starter system or may even sell the boat ...
#6212
