teflon o-rings
Black Talon created the topic: teflon o-rings
do they really last longer? is there special handling? any good deals?
#5930
marc replied the topic: Re:teflon o-rings
They do take a LOT more heat and abuse...what I DON'T like about them is that they have no memory, so if you remove them and put them back, they are loose. In face after you've run the motor a bit, if you move the pipe around a bit it gets loose. Personally I only use them when I absolutely have to. ie: on pipes that just eat up regular viton Orings because of bad design.
A good flange should not eat up the Viton Orings. Just my opinion.
Best source I know for the Teflons is www.mcmaster.com
#5935
Black Talon replied the topic: Re:teflon o-rings
thanks for the help,again!
#5941
Time to create page: 0.274 seconds
