Jims
seadams created the topic: Jims
Anyone have any idea what going on with the dock?
scott
#5798
marc replied the topic: Re:Jims
Looks like a DNS issue. Some can get on some can't. I was on this morning...now I can't get on.
#5799
mjmsr59 replied the topic: Re:Jims
been trying for 2 days,,not logging in...glad i"m not only one...:angry: :clapping: :angry:
#5802
Ronald Olson replied the topic: Re:Jims
Lots of complaints all over. I've had zero problems even after trying other browsers.
#5803
Billium replied the topic: Re:Jims
I was on this morn.B) But now i can't :cry: i'll keep tryin:dash:
#5807
tetrat replied the topic: Re:Jims
Me too here in Spokane. Yeterday evening nothin, then this morning got on once.. Nothing since then..:(
#5808
mitchesx replied the topic: Re:Jims
I'd have to agree with Marc, probably a DNS issue -but depending on everyone's locations, it could also be a routing issue, if a central router is down somewhere on an ISP, or a series of upgrades are being done, intermittant outtages of certain resources could occur....
#5809
A couple of simple tests you can do:
go to a command prompt (start -> run -> type CMD (in Xp or Vista), and hit enter or click ok.
at the command prompt type: ping www.jrcbd.com and hit enter.
You should get four replies from 66.64.192.120.
If that works, You can just type: 66.64.192.120/ (instead of www.jrcbd.com) into your address bar and if it is DNS causing the issue, the page will display. This will get you around the DNS problem
If you get request timed out, DNS isnt working, or you cant route to the site due to an ISP somewhere.
To check that, type in the command prompt:
tracert www.jrcbd.com
you should get a number of gyrations until it says trace complete. If you get a bunch of asterisks and a time out, its routing, basically an ISP. They'll have to get their problem solved before you can get to the site in this case. Hope I didnt kill all of you with TMI:ohmy:
I also previewed my post - the IP addresses became links so some of you may be able to use them to get to the site. Hope I helped somebody!!
#5827
Well you just did me:? wt frick did that all mean LOL:ohmy: I have trouble with right clicking still..:dash: :dash:
Gyrations Not with my back!!!:cry:
#5832
Still can't log on :meidiot: my clicker finger is gettin a blister :dash: maybe they will get it fixed today :worship:
grrrrrrrrrrrrrrrr Bill
#5842
