What prop is Wally using to go 80????
gforce created the topic: What prop is Wally using to go 80????
Just curious what prop Wally is using to go 80mph?? Thanks GG
#5630
Drinking Gas replied the topic: Re:What prop is Wally using to go 80????
Not 100% sure but he has run a 2716-2 special prop and a H 50
#5631
marc replied the topic: Re:What prop is Wally using to go 80????
I don't know which props he's using, but I am pretty certain they are from Chris Hoffman.
#5635
Ronald Olson replied the topic: Re:What prop is Wally using to go 80????
He was trying different props at the Flint record trials but mostly with Chris' H-50 reworked.
#5646
gforce replied the topic: Re:What prop is Wally using to go 80????
How do I get ahold of chris Hoffman???
#5647
I sent an email to this address. This email address is being protected from spambots. You need JavaScript enabled to view it.. Is that him???
#5648
#5649
Tahoe1970 replied the topic: Re:What prop is Wally using to go 80????
gforce wrote:
Gforce...I have many props that run on my cats , The problem your gunna find is that the Prop is only one peice of the Puzzle. It's a combination of several things , Most important is the experience and ability to run and fine tune the set/up. Most could run the boat....but would destroy it before they ever Seen 70ish...............
Later WallyB)
#5651
Yeah Wally I hear you. I am aproaching the 70's with my Seducer and every time the boat wrecks theres something new broken. Yesterday I flipped the thing and bent my rudder 90 degrees. I never thought that the water would be that hard but it turns to concrete at those speeds. also the seducer hull seems to stop working up around the 70's. It just starts skipping like an electric boat. Anyway I am not the best boat rigger out there but I pretty much copied a proven setup. From now on I will be just fine tunning. I hope to get the h50 to work but I'm sure it wont work like it does on your drag cats. Thanks for the help. I have contacted Chris and a modded h50 is on the way. Thanks all have a great day...
#5652
gforce,
Is that a Seaducer CAT you have at near 70mph???
#5653
