what props to run on Aeromarine xxx
Hype created the topic: what props to run on Aeromarine xxx
Was wondering what would be good props to run on the Aeromarine xxx hull with J&G top end.I mostly run in salt water. Can someone out there have any tips?
#5109
marc replied the topic: Re:what props to run on Aeromarine xxx
I had that combo at one time. Ran it with a 6717/3 but it lacked a little bit of grunt. It ran really well with a 7016/2 and I think maybe even a 7015/2 or a trimmed down 6717/3 might work well. The J&G top end kit tends to like to be propped to revv more than the typical modded 260s.
#5110
Scott replied the topic: Re:what props to run on Aeromarine xxx
Pending on how high drive is set on transom, will have a large bearing on how much bite prop will have.
If your drive is really low right on kiel, then a 6516/3 will do really well IMO.
Drive is up higher ... the 7016/3 may be the better choice.
#5111
