Zenoah komatsu and zenoah z-power
Mazwan80 created the topic: Zenoah komatsu and zenoah z-power
Hi,
Hi im a rc boater in Malaysia i have F1 catamaran and mono cougar powered modified zenoah 26cc komatsu.
I have a question about this to type of zenoah komatsu and zenoah Z-power, some say z-power is made in china and komatsu made in japan. We have encounter this two type brands and we found that brand zenoah z-power stock engine abit left behind compare to zenoah komatsu stock engine prop, body hull, hardware setting is the same even we change both engine using 813A carb.
I wonder any of u guys notice this or not.
Tq
Mazwan
#4701
seahawkwa replied the topic: Re:Zenoah komatsu and zenoah z-power
Specifications
Engine Type: 2-stroke Water cooled
1. Piston Displacement:
25.4cc
2. Bore x Stroke:
34 x 28 mm
3. Max Power:
1.5KW/12000RPM
4. Max Torque:
1.5N.M/9500RPM
5. Min Idle Rotate Speed:
3500RPM
6. Compression Ratio:
8.4:1
7. Ignition:
CDI
8. Spark Plug:
A7RTC
9. Carburettor: BM644
Diaphragm, butterfly valve type
10. Air Filter:
N/A
11. Start Mode:
Pull Start
12. Clutch Style:
N/A
13 Average Fuel Consumption:
Less than 710g/ kw.h
14. Lubrication(2 stroke Oil)
20:1
15. Dimension:
200 x 140 x 182 mm
16. N.W/G.W:
1.70/2.25 kg
17. Carton Size:
245 x 19 5x 195 mm
is that the sort of motor you are talking about . a cloned motor.??
Model G260PUM
Type 2 cycle piston valve type gasoline engine
Cooling System Water Cooled
Bore x Stroke (mm) 1-34 x 28
Displacement (cc) 25.4
Maximum Output Net ps (kw) -
Gross ps (kw) 3.15 (2.32)
Maximum Torque Net kg-m -
Gross kg-m 0.21
Rotation Direction Counter-clockwise
(viewed from PTO shaft)
Fuel Pre-mixed Fuel, 25 (Gasoline) : 1 (High grade 2 cycle engine oil)
Fuel Tank (lit) -
Lubrication Oil High-grade 2 cycle engine oil
Carburetor Diaphragm, butterfly valve type
Ignition CDI
Spark Plug RZ7C
Starter Recoil starter
Air Cleaner Type -
Overall Dimention Length (mm) 142
Width (mm) 160
Height (mm) 181
Dry Weight (kg) 1.54*1
#4718
pic is of zenoah clone .
#4719
pic is real zenoah .
i beleve the clone dosent have the same coil as real z and revs less and less power , and must be other diffrences.proble cheeper bearings seals etc???? . it would be good to know....
is this the difrent motors you are talking about or ???. is there diffrent ones again.
#4720
Mazwan80 replied the topic: Re:Zenoah komatsu and zenoah z-power
hi,
Sorry i been away on vacation, Z-power is not a clone but done by other company, Aswana company base in china. That why the box packaging different Z-power come in white paper and Komatsu is brown box. The Zenoah Z-power have same cource coil, carb 644 and everything is the same. performence a bit less than Zenoah komatsu. Z-power got Zenoah logo on head block
I know between Zenoah and China clone zenoah. China zenoah have black coil,metal water jacket.
#4726
Mazwan80 wrote:
have you got enny pics of the diffrence. ive never know the motors to come enny diffrent . ive always only seen the box`s with the z and white not brown in rc car or boat motors......
i do know the zenoah are now run under huscvana ( dont know corect spelling on that), and are no longer under komatsu ... but every box i have here and manual say made in japan not china??.
im i rong or . is there more to this ..............
#4734
tianglampu replied the topic: Re:Zenoah komatsu and zenoah z-power
i just receive stock zenoah from US last week and it's Z-power not komatsu(look from the box).How you compare both zenoah-you cannot get the same speed even you run same type of boat and same hardware....
#4736
tianglampu wrote:
We test between Z-power and Komatsu with F1 boat not in same boat 1 using komatsu and the other 1 used z-power.
#4738
