How to measure timing?
timberjack73 created the topic: How to measure timing?
Marc or Scott. is there a how-to article on the correct way to check intake and exhaust timing and compression on zenoah? Such as the article that Scott did on modding the cylinder and what tools you would need. Sort of a step by step article.
#4693
marc replied the topic: Re:How to measure timing?
That's a good idea! We will have to do one. I like it when readers tell us what they need! Thanks!
#4694
manyhobbies replied the topic: Re:How to measure timing?
I have directions on how to properly setup a degree wheel on my website. I also now offer a degree wheel kit that will help you to accurately check and change the timing and I'm in the process of coming out with a easy to use tool to check squish/piston to head clearance . I am also in the process of writing up how to properly use the degree wheel with accurate results. This write up will also explain how to check squish/piston to head clearance. There is already a lot of info out there on this if you research it. I will have this type of info posted on my site for support of my products.
This can be found here www.extremecustomhobbies.com
If you need any questions answered please dont hesitate to ask as we all help one another. RUSS
#4835
I have written an article that will cover port timing and squish measurements...it will be online very shortly...I have just asked Scott to go over it and give his input before I put it live. Look for it in the next day or so. :)
#4840
