Trim tabs.
uprr created the topic: Trim tabs.
Any one ever make any trim tabs that work off an unused channel on the remote?:huh:
#4088
Scott replied the topic: Re:Trim tabs.
Read MANY a thread on those toying with the idea, but never seen anything ever come to market.
Generally if you are finding the trim your boat requires going slow too going fast changes enough to require a TAB position change ? ..... You have other bigger issues needing to be dealt with such as C/G, warped hull bottom or wrong drive / prop position on transom etc. :huh:
#4089
uprr replied the topic: Re:Trim tabs.
Thanks for the heads up. I don't have a running issue at this point( building a new hull). I used to work in the pleasure boat industry and have owned several boats and was just toying with the idea. If I go thru with the thought I'll probably use a larger hull( current build is 53\" w/o outdrive) that way I'll have more room for \"extras\".:laugh:
Thanks again and happy boating!
#4092
