floatation?
uprr created the topic: floatation?
I'm looking for which floatation will do best? Will spray foam(great stuff) or should I just use foam board cut into pieces? I know how spray foam expands and can cause problems so I would use it in small layers and the stuff is pretty light. but on the other hand... PLEASE HELP!!:blink:
#3963
Steve Seebold replied the topic: Re:floatation?
Go to Walmart and buy some pool noodles. They can be cut to fit in any space and they're cheap.
#3967
marc replied the topic: Re:floatation?
Like Steve said...pool noodles...you can also get it in flat boards now too which works good for cowl and riggers.
The spray foam will eventually get soaked and weigh a ton...will rot your boat and weigh it down a lot...been there (a long time ago) never going back. Pool noodles will also take water over time, but they cost very little to replace. Once a year is usually plenty.
#3969
Piratefish replied the topic: Re:floatation?
All I can say is pool noodles! If you want to get fancy you can order closed cell foam in sheets or cylinders from www.closedcellfoams.com :cheer:
Piratefish
#3970
uprr replied the topic: Re:floatation?
Pool noodles it is!! Thanks every one for your help. This site is the BEST!
#3971
Time to create page: 0.206 seconds
