what controler /radio to buy..????
seahawkwa created the topic: what controler /radio to buy..????
hi all im trying to work out the best value for $ controler avalable . and what is best fm 27ghz or 40 ghz. (in australia and not alowed i think to use 75ghz).
or the 2.4 spectum..?????/ also is the spectrum dx3r enny good for boat use or are thay the same as the dx3 and loose reseption over water.
what is the jrxs-3 controler like ???/.
or what is the fatuba faaaast sistom like ???/.
im wanting a controler that will also have good range also as its more for sport boat.
to meany to deside when i dont realy know whats good and whats not....
also what radios have the australian C-tick certificaton. and what dose that mean.
if you have a radio with out that.:unsure: :unsure: :unsure: :unsure: :unsure:
#3711
Dicko replied the topic: Re:what controler /radio to buy..????
I personally run a Airtonics (Sanwa) M11 with a spektrum pro module. I only use spektrum pro receivers now with the capacitor installed to stop any low voltage cutoffs from excess servo draw. I have used a standard spektrum receiver, but did have issues with reception with it and do not recommend the standard spektrum setup.
my friend runs the JR XS3 which if bought locally will have the C tick (which means it has been inspected in Australia for compliance with Australian laws). He has had no issues and having owned one myself in the past they are a good unit. the plus with them is you can change the frequency quite easily if you have a conflict with another user at the pond.
you are correct about not being able to use 75 mhz in Australia. only 27 & 40 mhz for general purpose, 36 mhz for air and water and 2.4 ghz is also for general purpose.
I know people do favour the faast system over the spektrum one, but if set up correctly spektrum does work.
I strongly recomend getting the best you can afford, there's no point having a runaway boat that can cost you money in a damaged boat as well as hurt an innocent bystander if it hits them at speed.
#3748
Time to create page: 0.218 seconds
