Rudder Servo
RUMBUM created the topic: Rudder Servo
Would the futaba 3305 work for a 50 inch cat??? Later on planing to get the 5301 or is this to much??
#3632
marc replied the topic: Re:Rudder Servo
I wouldn't try my cat to that servo. It's only rated 124 oz/in torque at 6v. I try to use servos that are rated 180-200 oz/in or more...I'm old school and still use the old reliable 1/4 scale servos with metal gears for steering in most my boats.
This is one I use a lot...inexpensive and works well: www.servocity.com/html/hs-755mg_1_4_scale.html
#3633
RUMBUM replied the topic: Re:Rudder Servo
Can I use Hitec servos with a futaba fm 75mhz reciver?? if so what servo should do yje work?
#3634
No reason why the Hitec servos wouldn't work with your 75mhz Futaba. Just make sure the pinouts are the same. If you have a system that isn't VERY old, the servo pinouts are universal, so not a problem. From right to left, Black, Red, White.
#3635
Time to create page: 0.433 seconds
