Which gasoline pump???
skyray created the topic: Which gasoline pump???
Which gas pump are you guys finding the best to use????! I have tried the 6 shooter gasoline model but have had numorous problems! the internal hose keeps coming off the plastic nipples and the hose deterioates rapidily,goes flat(collapse),the crank turns too hard and the rollers wear away! Never had any problems with the nitro model???? Is there a squeeze bulb out there that will stand up to gasoline????Any recommendations is appreciated.............
Ron
#3151
INEEDSPOTS replied the topic: Re:Which gasoline pump???
I use the Hangar 9 Ultra Fuel Pump.. works flawlessly.
www.hangar-9.com/Products/Defa...x?ProdID=HAN155
#3153
marc replied the topic: Re:Which gasoline pump???
Ditto what Will said. I use the same...have 2 of them without problems...had them for several years.
#3154
IMPBA3548 replied the topic: Re:Which gasoline pump???
MPI here, have had three of them for a few years, no problems with them.........
mike sr
#3159
skyray replied the topic: Re:Which gasoline pump???
thanks fellows! I see noone is using the Dave Brown 6 Shooter gas pump! and I can see why with all the probems I am having!
#3161
I never heard of of an MPI????? where can one get one??? or see what it looks like???
#3162
Okay, I see the Hangar 9 ULTRA pump will work for nitro or Gasoline!, that is the way to go.....I am going to toss this 6 shooter!
#3163
Scott replied the topic: Re:Which gasoline pump???
Hanger 9 is what I use .... great little pumps that typically last 3-4 years under monthly use.
#3166
MPI, I believe is Model Products Inc, they are handled by Horizon Hobby, our local hobby shop has them. They are 10 to 12 dollars, have a chain to connect to the handle of the fuel container.
mike sr
#3207
Ronald Olson replied the topic: Re:Which gasoline pump???
Has anyone tried the Sonic-Tronics pump? They had it on sale at the Toledo show complete with the gas tank for $40.00 .
#3345
