Rigger set up
highcomp26 created the topic: Rigger set up
What is the recommended strut set up on a rigger, do you use the same as the seaducer hydro strut set up found on the site by Marc?
#2992
Scott replied the topic: Re:Rigger set up
highcomp26 wrote:
That question has no definitive answer :S ....
Pending of Riggers style, 3 point, 4 point, weight distribution and ride attitude requirements, the struts depth angle and prop used will all be part of the ideal set up specs.
So lets turn this around and ask: ..... What rigger are you working with ?
#2993
highcomp26 replied the topic: Re:Rigger set up
Sorry I am a rookie, its a warlock rigger and I will be starting out with a 6719-3. I really just want to know if the starting point will be the same as the hydro as far as placing on the table flat and adjusting the strut the same way
#2994
marc replied the topic: Re:Rigger set up
I would start the same way, but as Scott said, each one is a different beast. If it has rear sponsons I would start flush with them. This is assuming you have no instructions from the manufacturer. Scott has more experience than I with riggers, so I would listen to his advice! BTW, some ABC props are killer on riggers and hydros. :)
#2997
6719's are GREAT rigger props and seem to work best when they can run with water just over the top of props hub.
So what I would do for a baseline set up would be place boat on set up table with the flat portion of tub level with table, then set depth of prop/strut so the top of drive dog/ strut housing is level with set up board.
JMO ...
Scott
#2998
Ok Scott thank you very much sir for the baseline set up, thats what I was looking for . Thank you to Marc, I will let you all know how it goes.
#3002
