Call me cheap...but is the salvageable?
marc created the topic: Call me cheap...but is the salvageable?
Noticed this when doing a maintenance on one of my boats...at first glance it looks ok, but see second picture. About half of the outside strands are broken near the welded junction of the flex/shaft. I'm wondering if this could be salvaged by re-soldering with silver solder? All I have here is Stay-Brite silver solder...what do you guys think? I know I should just chuck it and get a new one but... :D
#2427
Roxyflash replied the topic: Re: Call me cheap...but is the salvageable?
When i see that i throw it out not worth loosing a prop over.
#2428
IMPBA3548 replied the topic: Re: Call me cheap...but is the salvageable?
What will happen is the short pieces will fall off when you bring it up to heat and leave a big void where the broken ends were, I have heated the stub shaft and cleaned out the end and saved that, and the flex could be cut back and reused. I have reused the flex with a longer stub shaft so it can be cut back and reused and get the proper length back.
mike sr
#2429
marc replied the topic: Re: Call me cheap...but is the salvageable?
Thanks. I will keep it on the side for now and might try salvaging the propshaft like you mention Mike. Are these cables soldered or brazed? I thought they were brazed?
#2430
Scott replied the topic: Re: Call me cheap...but is the salvageable?
Pretty sure they are attached to stuff shafts with @ 15% SILVER SOLDER.
Sta-bright is about 3% silver I believe.
** Save the cable for an application that uses a shorter cable & cut off that section, defiantly don't just re-solder and use it !
#2431
gibbscamuser replied the topic: Re: Call me cheap...but is the salvageable?
Is a $25.00 shaft worth a $75.00 prop?
#2432
I know the $25 cable isn't worth losing a prop over... I was just trying to find out if it can be fixed. It will go to the dumpster. :)
#2433
Jim Geiger replied the topic: Re: Call me cheap...but is the salvageable?
Save the stub shaft you never know when you might need it, I use them to make the shaft in the prop gages I do, and I also give them to the guys that run square drives.
Jimmy
#2434
Radamus replied the topic: Re: Call me cheap...but is the salvageable?
I've done it before just to say I did it, but it really isn't worth the effort, wouldnt do it again.
#2435
Good choice, Marc.
Steve
#2436
