Motor placement in Lazer 45
ScorpionMarine created the topic: Motor placement in Lazer 45
I got a Lazer 45 and it was already set up with a 260 and cc drop mounts. I got the same mounts and all and tryed to put the hatch on the boat with the engine and it does not fit. The orig owner didnt run a hatch .....
My question is where should the motor be (from transome to spark plug) so that the bubble hatch with scoop will fit???
Thanks
Roger
#2281
ScorpionMarine replied the topic: Re: Motor placement in Lazer 45
OK SOMEONES GOTTA KNOW!!
#2282
marc replied the topic: Re: Motor placement in Lazer 45
Here is the setup sheet if this can help. :)
www.modelgasboats.com/index.ph...id=201&Itemid=0
#2283
