Octura strut blade specs, Aeromarine not available
benjimolina created the topic: Octura strut blade specs, Aeromarine not available
Does anyone know any specs on this strut blade?
www.rocketcityracing.com/cart....tab-description
Mainly how long it is...
thank you very much!
-Ben
#25495
Bob DeCortin replied the topic: Octura strut blade specs, Aeromarine not available
Even Octura didn't really make it clear.This might help or email RCR and ask them.
web.archive.org/web/2005032300...ura_catalog.htm
#25496
tootalltechie replied the topic: Re:Octura strut blade specs, Aeromarine not available
Is there not a standard length? It does say it's bored at 11/32 and has been profiled on the bottom. Measuring the photo doesn't work for rough idea?
www.rocketcityracing.com/image...VMBO__82108.png
Sent from my SM-T530NU using Tapatalk
Rough guess 1.75 to 2" total length
#25497
Canadian Hot Rod RC Boats replied the topic: Octura strut blade specs, Aeromarine not available
rocketcityracing.com/cart.php?...tab-description
Octura Adjustable Strut for thru hull or stern mounting - From lower edge of bracket to center of prop shaft - 2-3/16 in. max - 1-3/16 in. min.
bored for 11/32 tubing
#25498
benjimolina replied the topic: Octura strut blade specs, Aeromarine not available
So i am not too good with interpreting blade measurments, How would this math up with aeromarines strut blade from #1402 in this page
aeromarinerc.myshopify.com/col...-assembly-45-90
#25499
The Aeromarine struts come in 2 sizes as follows
"The Strut Blade provided is streamlined and profiled for virtually drag free performance. They come in two sizes, 3-3/16" and 3-11/16", slotted to allow for a large amount of trim adjustment. " These measurements are from the bottom of the strut to the top of the strut blade. I would assume (not good sign) that the strut blades would have about 1" of adjustment.
#25505
